Should I change my Beovision 7-55 mark2 to an Eclipse 55?
This post has 19 Replies | 0 Followers
Sweden
Posts 357
Silver Member
Martin Posted: Thu, Dec 7 2017 5:42 AM
I am considering changing my 5,5 year old Beovision 7-55 mark II to an Eclipse 55. Do yoy guys think it is a good thing to do or what do you think?
I know that the PQ is extremly good on the 7_55. What do you think?
best Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
olvisab
Posts 1,391
olvisab replied on Thu, Dec 7 2017 6:25 AM
I also own a 7 55 mk2 and I have tested the eclipse and the loewe bild 7 in the same store, frankly for everything full hd I still prefer the pq of the 7 55. Its deep black still amazes me even compare to an oled.
If you need 4k then that's another story.
Until 4k is needed and we are far from that due to the lack and interest of the source, at least in France, I consider an "upgrade" a complete waste of money.
Oliv
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Sweden
Posts 357
Silver Member
Martin replied on Thu, Dec 7 2017 6:31 AM
Hi
great thanks for hour answer.
best regards
Esax
Posts 323
Esax replied on Thu, Dec 7 2017 8:27 AM
The 7-55 is to good tv to change if not need for bigger or 4k. Even the center whit bolab 10 is better. Because the voices is much neerer the center of picture than whit the eclipse. I’m suprised no one ever notised that. You can set the sound higt whit eclipse but it still not good enough.
That was my no go. And the lack of 4k material from viasat parabol.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
olvisab
Posts 1,391
olvisab replied on Thu, Dec 7 2017 8:49 AM
Esax:
Thanks for your opinion regarding the beolab 10. I tried every other center speaker of b&o and the beolab 10 was finally the best choice.
Nieli
Posts 27
Nieli replied on Thu, Dec 7 2017 8:56 AM
Hi
I’m a owner of the BV 7-55 MK II since Januar 2013. I was thinking about the Eclipse (55 or 65) too.
After all this years I think the picture quality is amazing and can still mess with the Oleds. It is important what PQ  you get from the sources. Most of the times I watch TV over SAT with 720p and therefore there is no need for a new TV. Even BluRay looks amazing too!
And the most important thing for me, except of the price tag, is that my older B&O parts (BeoSystem 7000) can’t be integrated with the Eclipse. There will be no ML/NL-Converter offered from B&O. So I’ll go on with my BV 7-55 MK II the next years and will see what´s on the TV-sector in future. And now Loewe TVs sounds more interesting than Beovisions for me…
Thomas
olvisab
Posts 1,391
olvisab replied on Thu, Dec 7 2017 8:56 AM
There is a perticular thing in the 7 55 that finally brings something more special.
The frame of the new screens from whatever the manufacturer is very thin. The pictures is then close to the wall and its color. The wide frame of the bv 7 gives a cinema style picture. It magnifies the picture when the very deep blacks blend perfectly with the black of the frame.
Sweden
Posts 357
Silver Member
Martin replied on Thu, Dec 7 2017 10:32 AM
What I can read from you guys is that it is "stupid" to change a BV 7-55 MKII to an eclipse.
A question: Is the Beolab 7-4 on par with Beolab 10 regarding soundquality?
Best Regards
olvisab
Posts 1,391
olvisab replied on Thu, Dec 7 2017 11:17 AM
I have tested every bl7 and for me it is the worth...
Sweden
Posts 357
Silver Member
Martin replied on Thu, Dec 7 2017 12:33 PM
Hi Olvisab, Do You know how many "screen"-hours you have in your BV 7-55?
I have 5.500 hours and are thinking of how long time I can keep my 7-55 before it gives up.
Have You heard anything about how well the 7-55 markII hold up against faults of everykind?
Best Regards
olvisab
Posts 1,391
olvisab replied on Thu, Dec 7 2017 12:54 PM
I have 5600 hours. The tech guy I know (official bang olufsen service center) has never had any for repair. The life is at least 7/8 times the count of hours we have.
There 2 fans under the tv on each side, check that they work and use an hoover sometimes for removing the dust on them.
Millemissen
Flensborg, Denmark
Posts 14,680
Martin:
best Regards
If you are happy so far with the BV7 - and maybe even have a ML-based setup connected to it - don’t panic.
The BV7-55 is a mighty fine tv.
Just wait - there will be other B&O tv’s, when you really need a new one.
Razlaw
Posts 4,345
Razlaw replied on Wed, Apr 21 2021 11:13 PM
Found this old thread while researching the issue in the title. I have almost decided to replace my 7-55 with a 65 inch Eclipse. I have 50s as fronts and 12-3s as rears. Any opinions? Particularly sound quality given advancements in technology and the fact that the Eclipse would have both 50s and 12-3s in the setup menu, unlike my 7-55.
Razlaw
Posts 4,345
Razlaw
Posts 4,345
Razlaw replied on Wed, Apr 21 2021 11:14 PM
Razlaw
Posts 4,345
Razlaw replied on Wed, Apr 21 2021 11:15 PM
Any thoughts on the question in this old thread?
Razlaw
Posts 4,345
Razlaw replied on Fri, Apr 23 2021 2:24 AM
Old thread......but is exactly the question I am asking myself.  I am thinking about an Eclipse. Any thoughts on what if any improvement in sound I might get upgrading from a BV7 to an Eclipse? Connected speakers are 50s and 12-3s.
Millemissen
Flensborg, Denmark
Posts 14,680
Razlaw:
Although the 7-55 still is a good tv, I reckon that most people will say: you won’t look back once you have an Eclipse....especially with the 50’s and the 12’s as speakers.
Michael
Sweden
Posts 2,578
Michael replied on Fri, Apr 23 2021 12:33 PM
One thing I really miss with a “real” beovision is the anti glare glass. My oled eclipse is really horrible at glare. I have to close my blinds all the time as it is incapable of removing even the smallest light reflections.
Razlaw
Posts 4,345
Razlaw replied on Fri, Apr 23 2021 1:12 PM
Michael:
One thing I really miss with a “real” beovision is the anti glare glass. My oled eclipse is really horrible at glare. I have to close my blinds all the time as it is incapable of removing even the smallest light reflections. Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Thank you. I have large east facing windows in the room so that is something I will have to consider.
Page 1 of 1 (20 items) | RSS
