Hi experts,
I have an issue in an installation.To distribute masterlink i use Beolink wireless 1.
One of the receivers are connected to both a beolink active and a beolink 2000... for some reason this does not work well.. If I turn off the beolink 2000 everything works fine. If I turn on the Beolink 2000 the system starts to act strange.It is not possible to connect more then one device to a beolink wireless 1 receiver?
All inputs are welcome.
Br
LArs
Hello LarsBeolink 2000 ?One transmitter will support up to 7 receivers.Each receiver will support one product.Let's be crative.Use beolink active in option 5, and the Beolab 2000 in option 6, Try that, or vica verca.Pls be born in mind, MK I or MK II: of BL Wireless.Or you have a cable ML cable Issue (Faulty or wrong connected ML cable)Pls read the manual very carefully and follw the instruction promtlyBrgds/Fritz
Glad to hear it worked out
