I have an old pair of BeoLab 3's and a BeoCenter 2. Is it possible to run only the socket unit to the BL3's, running only one input into the Aux? Ideal would be to just use them with a non-B&O TV. I'm guessing it would be easier to just get PowerLink analog adapter cables, but if the Socket Unit idea is possible, it'd be a lot cheaper to get it running like that.
