Hi, all.
Asked a similar question not long ago, but recently changed my setup.
In my livingroom I have a Beosound 9000 (MKI) connected to my Beosystem 3. The BS9000 plays through a Beolab 7-2 I use with my Beovision 4-50. Works just fine. But the thing is, that in the same room I have a Beomaster 5500 that turns on too, every time I turn on the BS9000 using Beo4. How do I stop it from doing that? Before I had the BS9000 connected to a Beovision 7, and it played through the same Beolab 7-2. Worked just fine, WITHOUT the Beomaster 5500 turning on.
Please advise.
All the best
/ Bo Xamuel
