Feet for beosystem 4500
This post has 14 Replies | 0 Followers
bidstonhall
Thailand 5560 miles from Struer
Posts 363
bidstonhall Posted: Sat, Jul 27 2013 8:31 AM
hi guys, does anyone know where i might acquire a set of feet for the beosystem 4500, or has anybody improvised because they are quite hard to locate, if so how did you do it, cheers
Millemissen
Flensborg, Denmark
Posts 14,680
Far, far away from Thailand:
http://radioogtveksperten.dk/tilbehoer-44/beslag-53/
bidstonhall
Posts 363
hi, just had a look at the site, can't see anything
davieav
chester UK.
Posts 49
davieav replied on Sat, Jul 27 2013 9:27 AM
i have 3 you can have .. not enough for you but it is a start.
Millemissen
Flensborg, Denmark
Posts 14,680
bidstonhall:
The link works perfect for me (copy/paste).
I supposed you mean the metal things/brackets for hanging?
Or did you mean the small plastic things for the underside to angle the system if standing on a cupboard??
In that case, it should be easy to create a DIY solution.
bidstonhall
Posts 363
yes, it's the small plastic feet
bidstonhall
Posts 363
hi dave, 3 would be great, can i PM you
Millemissen
Flensborg, Denmark
Posts 14,680
P.S. I'm not giving away mine Big Smile
bidstonhall
Posts 363
is that brackets or feet, am completely confused now             Huh?
Millemissen
Flensborg, Denmark
Posts 14,680
The feets - the small (red) plastic things!
davieav
chester UK.
Posts 49
davieav replied on Sat, Jul 27 2013 11:43 AM
of course....think my email is on here
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
They are generally black and are used to angle the system up at the rear.
2 are used per unit and were supplied in the box when  the units were new.
Not many people use them and they generally disappear during the life time of the units along with the metal cable covers!
I got negative ebay feedback from a Norwegian customer because I did not supply them with a Beocord 3500. Just where he expected me to get them from baffles me. They were certainly not shown in the sale photos!!
Regards Graham
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Jul 27 2013 5:38 PM
Like these?
Ralf
Millemissen
Flensborg, Denmark
Posts 14,680
Exactly - so mine must be black too.
Haven't seen them for years - they must be in the original box in the attic
swo
Posts 15
swo replied on Mon, Feb 15 2021 7:28 AM
Does someone knows the dimensions?
it would be helpful for a DIY
Thanks Wolfgang
Page 1 of 1 (15 items) | RSS
