Currently I am restoring a BeoMaster 700K.
Unfortunately, it's integrated loudspeaker is worn out.Therefor I am looking for a replacement speaker.
The original speaker is a Sinus/Svenska, 0 4654 YK, 3.2 Ohm, 635 A.Possible replacements are:
The original speaker is a full range speaker with a double conus.So I am also looking for full range and double conus in the replacement.Who can help me find a speaker, webshop or reseller?
https://beoparts.com/2016/11/16/beomaster-speaker-o-4654-y/
I found a really good replacement speaker for the BeoMaster 700K.
It is a modern speaker but specwise comparable. And also the size is a perfect fit.So no need to create new mounting holes.
Also, the speaker quality sounds good.
Here's info about the supplier:
https://www.soundimports.eu/nl/grs-46as-4.html
