Hi, I purchased a Beoplay P6 about 6 months ago and loved everything about it so much I purchased another in the January sale primarily so that I could link them and get quality stereo sound. My problem is the secondary unit (which ever one I use) almost constantly suffers from sound dropout. Has anyone else experienced this? Thanks Neil
A well kept secret in B&O play “stereo pairing” land is you should always completely close the app (swipe up in IOS) once you have stereo paired the devices. This creates a lot more stability! You can actually also pair them with just some button combo’s without the use of the B&O app.(You can find the sequence on help section B&O site, use google)
keep in mind the two Beoplay devices simply cannot be separated for more then roughly 3 meters and always maintain line of sight principle. This gives best results.
Thank you very much for your help. I will certainly try this
