Hi All,
I've been relying on isolating bluetooth earbuds for work to block out ambient machine noise, with the adden bonus of music and podcasts to keep me sane.
Really like the look of the Beoplay H'5 but concerned about reviews of them falling out of the ears while moving. Has anyone tried using a custom moulded tip with the h5's like these snugs?
https://snugsearphones.co.uk/product/snugs-only/
Hoping they might eliminate any fitting problems.
BeoVision Horizon ● BeoLab 14 Subwoofer ● B&O Play A9 ● Beolit 15 ● B&O Play H8 ● B&O Play H5
Thanks Roy,
There seems to be so many mixed reviews on fitting. And quite a few like yourself who have no problems at all. Can i ask how close the standard silicone/foam tips are to the charging dock when the earphones are charging? Looking at the photos they seems to be pretty close witch might make charging with a more bulky custom mouded tip a bit tricky
