Beocenter 2300 Aux connectivity
This post has 1 Reply | 2 Followers
AVDoctor
Posts 1
AVDoctor Posted: Thu, Feb 25 2021 10:16 AM
Hi Folks,
Apologies if this is answered elsewhere, but I couldn't find this answer easilly.
I'm hoping to pickup a Beoconter 2300 fairly soon, which I will use with a pair of BeoLab 6000. I want to link this to toher hardware in my home, so need to take both a line into the Beocenter ( I guess the Auxbutton will route that for me) but I'd also like a line out to send to other amplifiers. (Non B&O)
Is the 7pin DIN connector both an input and output connector?
Is there a recommended supplier for these?
If so, I guess the line out is at a fixed level?
Many thanks.
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Feb 25 2021 10:51 AM
Hi and welcome to Beoworld!
Yes the AUX socket on the BC2300 is both an input and output (fixed line level), and can be used as described.  Select using AUX on front panel, SHIFT RADIO on BL1000 remote or A.AUX on Beo4.
And for cables I would recommend our site sponsor at the foot of the page or this link: https://soundsheavenly.com/32-music-input
Page 1 of 1 (2 items) | RSS
