Beolab 6000 buzzing
This post has 0 Replies | 0 Followers
kai
Posts 362
kai Posted: Fri, Mar 5 2021 11:09 PM
3200 with core plugged into aux socket and lab 4000 in one room with two further rooms masterlinked, kitchen has lab 6000 with active kit and conservatory 8000 with active kit. I can select aux as the active kits have the older software, however if i phycially select aux then simply use the beo4 volume up or down then i can bring the core through and it works well, howver intermittently there is a buzz through the 6000, the 8000 in thr conservatory are fine masterlink has been checked and it is fine, all sockets have been checked and again all ok, i cant think of anything else that will cause this problem, as its so intermittent, had anyone come across this issue, just to be clear when it does happen it affects cd and radio as well but only in the kitchen
Page 1 of 1 (1 items) | RSS
