Finally I got a nice pair of Beovox S60 speakers and as the title says I want to mount them to the trumpet stands (type 6009) I bought few months ago (thanks Dave!).It should be an easy task but I am missing something I don't have a manual for it but it looks that the speakers shall be simply hung up on the 2 black little screws of the stands. Unfortunately that does not work because the distance between the openings on the triangle brackets on the rear side of the speakers (which are intended for the wallmount) does not match the distance of the 2 screws?!As far as I know these stands should match exactly S60 (and also M70). Can somebody help me with this issue?Many thanks in advance!
Vintage Bang & Olufsen
Any idea?
