Beovox M100-2 midrange speaker required.
This post has 11 Replies | 1 Follower
Rtyu7
Posts 20
Rtyu7 Posted: Sun, Feb 21 2021 1:35 AM
Hi guys my legendary Beovox M100-2 speakers are having a problem the midrange speaker the one above the big bass woofer is producing voice coil touching distortion sound.
Where do i get another one of these from or where to get it repaired?
Does anyone know the original manufacture and model of this midrange speaker? I am aware a lot of beovox speakers used Philips parts.
Thanks for the help guys.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Sun, Feb 21 2021 4:33 PM
If the problem is because the foam surround on that small driver has deteriorated then all you need to do is pull that driver and have the foam surround replaced on it. The foam surround keeps the cone centered as it travels to produce sound. Once the surround starts to fail the cone will not be centered and start to rub. A good speaker repair shop can do that. If you are a DIY type person then you can purchase a replacement surround and make the repair yourself.
-sonavor
Rtyu7
Posts 20
Rtyu7 replied on Sun, Feb 21 2021 8:09 PM
I already did the foam surround on this ages ago and it was fine.
When the distortion happen a few weeks ago i thought the same so i brought new foam and glued it hoping it would center it but no luck.
Rtyu7
Posts 20
Rtyu7 replied on Fri, Feb 26 2021 1:11 AM
The speaker says on it 78 04 14
Anyone know what brand this is?
I searched the numbers in google but no luck
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Feb 26 2021 7:21 AM
The numbers are a date code - april 4 1978.
It's a Peerless KU45MRF - unique to this model (and Beovox M100).
You won't find it elsewhere.
And it's really a "Filler" unit rather than a midrange in the conventional understanding.
They rarely fail - apart from the foam surround.
Most likely a misalignment when it was refoam'ed.
Was it professionally refoam'ed? Shim'ed correctly?
Rtyu7
Posts 20
Rtyu7 replied on Fri, Feb 26 2021 11:31 AM
I brought the speakers on ebay with this drivers needing refoam i did it myself both mids worked fine for a good few weeks then this one failed and starting making voice coil rubbing distortion sounds.
So then i took the foams of brought new ones and glued them but distortion sound is still there.
I have done about a dozen refoams before i dont do anything fancy about centering them i just concentrate on the outline of the speaker and put the foam on neatly.
I have brought parts from you before, shall I send this to you for repair?
Rtyu7
Posts 20
Rtyu7 replied on Fri, Feb 26 2021 11:42 AM
Very interesting you call it a filler instead of midrange, I cut the wire off currently to disconnect it then i use the balance knob on my Accuphase amp and I can hardly hear any difference between the 2 speakers.
If any thing the sound is more clearer and cleaner more studio speaker like sound and I dont feel like i am hearing any less instruments or important sounds.
On ebay US there is a Peerless KO40MRF / K040 MRF 821385 8 Ohm 4" will this do ?
Rtyu7
Posts 20
Rtyu7 replied on Fri, Feb 26 2021 11:48 AM
1 thing i did change just before i had this issue was the speaker cables from the amp to the speakers, I changed to very heavy duty cables that look like car jump leads!
I have Accuphase pre amp and Yamaha P2201 power amp which produces 250 watt per channel.
I have a feeling the cables let in more power to the speakers and messed some thing up the red over load light came on a few times too.
Dillen
Posts 13,191
Dillen replied on Fri, Feb 26 2021 12:44 PM
The overload light coming on has nothing to do with the cables to the speakers.
And anything upwards of 0,75mm2 doesn't make much sense unless we are talking about hundreds of watts, very long cable runs or particularly bad cable materials.
Rtyu7
Posts 20
Rtyu7 replied on Fri, Feb 26 2021 7:40 PM
The cables did make a very noticeable difference to Bass it is a lot stronger.
Is Peerless KO40MRF a good substitute?
Dillen
Posts 13,191
Dillen replied on Fri, Feb 26 2021 8:23 PM
No, unless you used very bad cables first.
And no. Get the real thing if it needs replacing.
Manbearpig
Posts 908
I already told you via PM that there is no good alternative replacement and that originals are very sought after, rare, and therefore awfully expensive. You won't get a different answer here.
Greetings.
Page 1 of 1 (12 items) | RSS
