I have a few BS essence mk2 and an A6 that I'm trying to update the source lists on each one but when I make a change to the source list in the configuration it makes no difference when viewed in the B&O app to select a source to play. I can add sources using multi room but the local sources stay the same (line in, Tune In, Deezer). Is there a setting I'm missing?
