Hello, i’m new here and happy with my Beogram 1200, it turned good but the motor made heavy noise, so i took apart the motor and found the cushions dry, so i oiled and mounted everything, but by manipulating the motor some wires broke off were they were weld, and i don’t know anymore which go where.
my question is , Can i skip that switch and connect directly the red and blue 230Volt straight to the motor ?
thanks for you advise, Fred.
Why not do it right?Page 3 in the servicemanual shows the wiring diagram.
