As per the title, is it possible? Are they the same component? I’ve bought a used beo6 but the navigation arrows are worn so wondering if I found a cheap faulty beo5 with a.nice keypad whether they could be swapped?
Many thanks.
They are the same. The only change is the screen size.
Ah, you know... A little B&O here, a little there
