Beoplay M3 connection to BeoRemote One BT
crossbytje
Posts 224
crossbytje Posted: Tue, Apr 14 2020 2:35 PM
Today I received a pair of M3 speakers I bought in replacement of my dead Beolab 4s, which I connected to my pc.
In the app, there was the option of pairing them to a remote control: a BeoRemote One BT or an Essence. Since I have BR1 laying around, I tried to pair them, but it keeps failing.
Did anyone here succeed in pairing a remote to the beoplay network speakers? Any ideas on what went wrong?
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
1990
Posts 521
1990 replied on Tue, Apr 14 2020 2:51 PM
Two quick thoughts:
- did you use a BR One BT?
- did you use the Bluetooth pairing-menu or the Remote pairing-menu? They are different and sometimes lead to some confusion.
Using the ip-configuration-page instead of the app might help too..
crossbytje
Posts 224
It's a BT BeoRemote 1 indeed, and tried both through the remote pairing in the app and on the ip interface in a browser on the computer. Sometimes, the BR1BT quickly says 'pairing failed', other times it says nothing for a longer period of time..
1990
Posts 521
1990 replied on Tue, Apr 14 2020 6:25 PM
I’d try a factory reset of the BR One.
crossbytje
Posts 224
I'm a bit reluctant to do so, as I have completely customized it to my needs. Sources, list entries, names, etc. I use it to control an openhab server with a IR eye receiver, so all sources and settings map to my specific setup (sound, lights, itunes, tv, apps, my fireplace, etc.).
I think I'll just stick with it and try again some time later. I can already control an itunes instance and choose to let it multiroom stream playlists and online radiostations to other airplay devices, so I can easily add support for the new M3s too.
I was curious however to how the B&O ecosystem works with the BR1BT.
crossbytje
Posts 224
Problem solved!
Turned out I paired the remote to my macbook when I bought it, and then deleted the connection from the remote afterwards, but did not tell the macbook to 'forget' the remote. So as soon as I tried to connect the remote to a new device, the mac wanted to reconnect, which didn't work..
So now I paired the BR1BT to both M3s, will check tomorrow what it can do :-).
crossbytje
Posts 224
The BeoRemote One BT also did some updates on itself upon pairing with the M3!
CheapB
Posts 53
CheapB replied on Tue, Mar 23 2021 12:28 PM
Are you able to use MyButtons with the M3? I cant see any mention of a remote in the user guide
crossbytje
Posts 224
crossbytje replied on Tue, Mar 23 2021 12:59 PM
Yes, you can assign certain sources to the buttons.
Page 1 of 1 (9 items) | RSS
