Hi, I don't know if anyone can help me, but I've a beomaster 1900 who doesn't work anymore. Standby is functioning,but when I press another button the green play light flashes and that's it. The fuses are ok and I get around 124 volt when I messure the fuses (the switch for the voltage is set on 220volt). The relais is also responding. So I don't know what the issue could be.
Check for DC on an output from a cracked solder joint or a bad output stage.
