MC120.2 woofer, where to find a replace?
This post has 9 Replies | 1 Follower
Rockrest
Posts 4
Rockrest Posted: Sun, Mar 21 2021 6:55 PM
I got a pair of mc 120.2 speakers and one woofer is dead. Where i can find one?
Basstard
Posts 60
Basstard replied on Mon, Mar 22 2021 6:27 PM
Where are you located ?
Rockrest
Posts 4
Rockrest replied on Tue, Mar 23 2021 5:11 AM
Sorry😁 I’m in Finland.
loureed5
Posts 171
loureed5 replied on Tue, Mar 23 2021 12:50 PM
When you say the woofer is dead -what do you mean?
Perished foam surrounds ?, total burnout of voice coil ?
Noel.
Rockrest
Posts 4
Rockrest replied on Tue, Mar 23 2021 1:53 PM
Hi! Foam is replaced, but voice coil is burned. So completely mute/ dead😭
loureed5
Posts 171
loureed5 replied on Tue, Mar 23 2021 3:37 PM
So sorry to hear that, and it's going to be tough to fix the problem .
I've done an extensive search on Google ,through the web-sites I know about ,and the the only thing I could find was a foam surround for the woofer-(no re-cone kits though.).
Sorry I couldn't be much help,
Noel.
Rockrest
Posts 4
Rockrest replied on Tue, Mar 23 2021 5:13 PM
Yes it’s a tricky one. Thanks to you anyway! Second hand woofer is only solution, must continue the hunt.
loureed5
Posts 171
loureed5 replied on Wed, Mar 24 2021 12:17 PM
No worries.
Noel.
loureed5
Posts 171
loureed5 replied on Wed, Mar 24 2021 1:19 PM
Have you got a speaker repair business in Finland ,that you could send the woofer to?To be re-coned?
Noel.
Basstard
Posts 60
Basstard replied on Thu, Mar 25 2021 6:35 PM
If you plan to make a trip to Tukholma by cruise. Send me a message. I do have a pair of MC120.2 s that i´m not using. Send a message.
Page 1 of 1 (10 items) | RSS
