Hello everybody,
I am thinking to buy new B&O products for my new flat and I was wondering which solution is the best to stream my turntable.
For now, I have a Planar 2 turntable, plugged to my Beoplay a9 mk4. I want to buy a Beovision Harmony and I was wondering if I plugged my turntable via line in to the TV, if I could stream at the same time the sound to my beoplay a9? And maybe to another B&O speaker?
If it’s not possible, is there any solution to listen my turntable through more than 1 B&O system at the same time?
Thanks a lot for your advice.
Kind regards.
Didork:If it’s not possible, is there any solution to listen my turntable through more than 1 B&O system at the same time?
I use a BG6000 Line-in connected to a Harmony. The music can be NL distributed.
Thank you very much for your answer!
Turntables are analog - wouldn't digital streaming defeat the whole purpose of listening to vinyl?
Tifoso48:Turntables are analog - wouldn't digital streaming defeat the whole purpose of listening to vinyl?
