Beolab 8000
Libero
Posts 7
Libero Posted: Sun, Mar 28 2021 6:09 PM
Good afternoon.
I have a Beolab 8000 (with Beomaster 6500, Beogram CD 7000 and Beogram 5005). When I am playing some CD's or long plays (not all), the BL8000 speakers sometimes do not play all the music correctly. Sometimes the vocals don't sound or sometimes the guitars don't sound.
I would be grateful if anyone has this problem and how I can solve it.
Thank you very much.
Hungedu
United States
Posts 165
Hungedu replied on Sun, Mar 28 2021 7:49 PM
It sounds like you may have both of your speakers set to the same stereo channel. Check the switches on the back of each speaker, and make certain that one is set to L and the other is set to R.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Libero
Posts 7
Libero replied on Mon, Mar 29 2021 4:52 PM
Hello,
I have followed your instructions and the problem has been solved.
Very kind and thank you very much.
Antonio
Hungedu
United States
Posts 165
Hungedu replied on Mon, Mar 29 2021 8:42 PM
Glad it worked out! You're welcome.
Page 1 of 1 (4 items) | RSS
