Using Beolab 28 in a 5.1 environment
This post has 1 Reply | 0 Followers
Tifoso48
Posts 162
Tifoso48 Posted: Fri, Apr 30 2021 6:35 PM
I currently use beolab 18/19 as part of a 5.1 environment with a Marantz AVR.
Marantz utilizes a very excellent sound adjustment system.
Beolab has its own room adjustment system built in.
Will this become a conflict and of course with Beolab 28 you no longer have a separate subwoofer which is used as crossover for all speakers within  5.1.
do you think this would be a problem?
Tifoso48
Posts 162
Tifoso48 replied on Fri, Apr 30 2021 6:53 PM
should read:
The new Beolab 28 has its own room adjustment system built in.
Will this become a conflict and of course with Beolab 28 you no longer have a separate subwoofer which is used as crossover for all speakers within  5.1?
Page 1 of 1 (2 items) | RSS
