Connecting the Beogram 5500 Turntable to the Beoplay A9 MK2
This post has 2 Replies | 2 Followers
Kgomotso Mabokela
Posts 44
Kgomotso Mabokela Posted: Fri, Apr 16 2021 6:52 AM
Greetings mates,
I seek clarity, i tried connecting my beogram 5500 turn table to the line in inputs of the A9 (mk2). To my surprise the volume is super low and cant get much of a clear signal even if the volume was set to max. Do i need a phono preamp or? I was under the impression that the 5500 turntable has a in built phono preamp? I'd appreciate all the assistance & guidance.
Regards,
KM
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Apr 16 2021 7:32 AM
You'll need a phono RIAA pre-amp for the BG5500 - it doesn't have one built in.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
As Guy mentioned, the A9 doesn’t have a pre-amp, so you will need this pre-amp kit to connect the Beogram, which comes with all cables needed and full instructions, ready to “plug and play”:-
https://soundsheavenly.com/beogram-record-players/12-2196-pre-amp-bundle-for-bo-beogram-and-all-turntables.html#/36-output-5_pin_din_aux/41-power_supply-uk – please choose the “Twin RCA plugs” output option for your A9 mk.2 with red and white RCA input sockets.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (3 items) | RSS
