Hi
does anybody use Netradio on a Beovision Avant? Whenever I try to use it, it only shows the Bang & Olufsen test streams, and those don't even play. I get Connection Error.
Anybody can help with this?
Giovanni
I use it every day since it was added through an update a long time ago....without problems.
How are your ‘power saving settings’?
I think I have the defaults on power saver.
Network Power Saver settings (wlan, wake on lan...) are ON
auto standby 4 hrs
sound/picture economy mode is off
That's good news!
did you do anything special to your network setup or sign in to any Bang & Olufsen online products?
G.
Just an update here. My Avant 55 is still not able to access Netradio. The interesting thing is that by looking at the network traffic it's trying to access a website pnetradio.bang-olufsen.com which does not have a valid DNS entry. So, it cannot download the list of radio stations and hence cannot access the product.
I flagged this to B&O tech service and they are looking into it.
Ok so I solved the issue, thanks to B&O Customer service.
On the remote press:
If the above-mentioned steps have not updated the Net radio stations, kindly try the steps below:In the network settings:
Thanks Giovanni
