Ive been happily listening to BBC radio stations on my Avant until last week. Now, nothing. Other stations unaffected. Today there is a BBC message saying their radio stations are no longer available on this device. Anyone know whats happening?
This is a known issue as the previous poster mentioned.
You may be able to solve it by adding a custom URL through the TuniIn app.
Otherwise, a Raspberry Pi can be set up to re-stream the BBC station for your Avant.
It seems unconscionable that BBC would remove a service from hardware you have owned for years.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
Hello,
Your answer was intruiging. Do you have any instructions on how to set this up?
Cheers
Iain.
That is a funny one.
Yesterday late - as I read the thread - I turned on netradio on my V1 and saw that indeed it could not connect to the BBC channels.
Same there this morning.
However, on my Avant MK1 they play just fine (although rather lowres’ed at 128, which is no joy with bigger speaker setups).
And yes, they are on the same (wired) home network!
Anyway - at least when it comes to the V1/Avant MK1 platform - there is no TuneIn working there. See picture - sorry for the quality, too much light here this morning.
This is probably the same network that B&O is using with the Bang & Olufsen Radio - at least I hope so.
GlynRJ does not state which version of the Avant he is using - so a bit hard to say something to that really.
As always, details, details, details help a lot, when troubleshooting.
But alas, now I have to find out, why the stations are running fine on one tv and not on the other ;-(
Here comes the picture then
