I hace a pair of Beolab 5000 and i would like to connect them to my new beocenter 9300.
The notice shows that i can connect one panel to my beocenter (using one power link cable), and one power link cable to go from one panel to the other.
Is it ok for the stereo signal ?
Thanks for your respond
Thanks Ralf
Ok Lawrence Thanks
And set the switch at the speakers to left and right respectively.
Ok Dillen
