Hi all,
I have recently bought a BV 7-32 to replace my old BC1 in on of our link rooms. Am I right in assuming I need to set the BV7 to V.OPT 5 as a link room system (and not the main system)? Main system is a BV10.
thanks for any feedback/clue people are willing to give
regards
Torsten
Yes V.OPT5 for BV7 in linkroom, if you want to control video sources of the mainroom - if you want to control also audio sources, set to V.OPT6.
Videomaster BV10 must be set to V.OPT1 (video) or V.OPT2 (video and audio).
Stefan
Thanks, Stefan.
