Hi
I have an issue with my BM 4500. The balance display reads out “_ _ 0 8” and can’t be adjusted - same goes for the other sound options (though the current setting looks more normal). Only volume and start up volume can be adjusted accordingly.
As a result of this, there is no working left channel .. does anyone have a solution for this problem?
SOLVED .. I put it in test mode and cleared the RAM, that’s all it took ..
No, but I cleared the RAM and that fixed it.
