Hi
I need to replace the damaged 7 din pin plug on my 5500 turntable with another 7 pin plug. Could someone confirm if the attached picture shows the correct way to solder the wires to the new plug?
Chris
Looks right.
Thanks for your help Martin. Cheers.
Hi Martin,
I am looking to renew the 7 pin din plug on my Beogram CD 5500 but my wire colours are different.
Please can you advise the wiring positions for wire colours red, white, yellow, blue, black + bare braided wire.
Mamy thanks,
Colin
