Morning all,
I've more or less sorted the problems with my Beocenter 2000. The sound now works fully from both channels and i've learnt the stylus needs replacing. The final issue that I need to sort before sourcing a new cartridge is that the phono output is extremely quiet, I was told that it should make a sound by running my finger over the needle which is does but is only audible at full volume.
Would a broken stylus cause this?
Cheers
