Hi. I've got a TX2 where some unwanted friction (or stickiness) somewhere is making me have to press PLAY several times before the table responds as designed. I've tried lubricating everything the manual recommends, but no joy yet. Speculating the unwanted friction is at part 1614 or maybe 1603. Something sticks a tiny bit, but if give 1614 a slight nudge, 1603 disengages, the gears start turning and the tonearm moves in. I took out the piston (part 1646) which is in good shape and thoroughly cleaned things. On the verge of giving up. Any and all guidance much appreciated!
