I have a Beoplay A9 speaker and am connecting it to a Netgear DG834G Router which is about 5 years old. Every time i put in my WEP key in to the set-up software and click on apply the A9 trys to connect but the orange flashing light appears. When I take of the security password then the unit works fine on airplay anyone else had the same problem or could help me out.
Also I want to buy the Beovision 11 TV but am not sure if the CI slot will support Conax CAM cards does anyone have the answer for this one?
You need a new router. Make sure you pick one that works well with Airplay and not just the least expensive one!
Thanks for the tip. Before going out and buying a new router I done a firmware update on my router and got it all up and running with no drop outs and a strong signal up to the third floor. Thanks Guys
