I'm new to this forum and hoping somebody can help me.
I've connected my PC to our Beocenter 6-26 using the DVI input, but then nothing happens. Is there a manipulation on the TV. I'm not sure what to do next and the guide doesn't help a great deal.
You need to do two things (1) setup the association of the AV port at the back of the Beovision to the type of usage you plan (e.g. PC) and then (2) program your Beo4 with the [PC] softkey
Hopefully this extract from the reference manual (as opposed to the user guide) is more useful to you:
BeoNut since '75
