Made some adjustments to my multiroom settings which I haven't touched in a LOOONG time.
I reset the "LINK TO OTHER PRODUCTS" briefly to "none" on the Beosound Core settings and now it does not show any available products.
Power cycled all products and the "discover other devices" tab currently shows the other devices but when I try and select them in the "LINK TO OTHER PRODUCTS" tab it only shows "none" as the only option.
I feel like I might be missing something simple.
Is there a process or order I might need to do this?
Trying to connect to a BLC converter for a Beosystem3.
Thanks,
Michael
BS9000 + BS Core + Beosystem 3 + BL8000 + BL4 + BL2 + BL7-1 // BeoVision 7 32“ + BL8000 // Beoplay M5 // Beoplay S3 // 2x BL3500 // 2x BeoPlay A6 + 2x Essence Remote // 2x BeoSound 8 // Playmaker + BL6000
