Can someone help me to compare 3 of them? the P6 is near the cost of Beolit 20, is it worth it? And how good the Sound quality and the battery is between them?
Thank you very much !
Wow really? It is a strange design
But you mean the beolit 20 is not portable? Because of its size?
At least in the UK you now buy the P6 for half it's original RRP, so really a great price. It sounds best side-on where you get the best stereo separation. Where the 4" bass driver is pointed doesn't matter so much. Sounds better than the A1.
1. Hi, this offer only in Offline UK store not Online store?2. What do you mean by "side on"?3. It the P6 sound much better than the A1 gen 2 ? or just a slight edge?Thank you
jamospingal: At least in the UK you now buy the P6 for half it's original RRP, so really a great price. It sounds best side-on where you get the best stereo separation. Where the 4" bass driver is pointed doesn't matter so much. Sounds better than the A1. Indigo Card
Indigo Card
Although the B&O Beoplay P6 isn't fully water proof it comes with an IP54 rating which means it is splash and dust proof. It should be able to survive an accidental spill or two but we won't recommend taking it in the pool.
My Balance Now
