Beolit 15 dead - Service manual/spare parts anyone ?
Tomvdw
Posts 177
Tomvdw Posted: Sun, Jun 7 2020 4:47 PM
my Beolit 15 doesn´t work anymore.
Its strange behavour is: connectet to PC by USB and main power the LED is blinking orange, but only then ! It isn´t doing anything apart pressing power with showing 1 second the white LED. Even "charging" with >12 h like described above, no chance at all. With USB or main, there is nothing happen.
I tried already another (new) battery - the same behaviour :(
So either I need the service manual and/or a new mainbord or maybe the power supply board - nothing more possible as nothing more is build...
Any ideas / tipps ?
THX, Tom
Edhusky
Blaine WA
Posts 9
Edhusky replied on Sun, Sep 26 2021 3:46 PM
I’ve had the same problem for months.
Edhusky
Blaine WA
Posts 9
Edhusky
Blaine WA
Posts 9
Edhusky replied on Sun, Sep 26 2021 3:47 PM
I’ve had the same problem for months. Why doesn’t /can’t B&O step in and help?
leosgonewild
Helsinki, Finland
Posts 2,373
Are you able to run software update?
seethroughyou
UK
Posts 999
Beolit 15 is only 5 years old and they’ve started to die already. They don’t nKe them like they used to in the 70/80s.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
