It is a know problem.I am in contact with Bang & Olufsen support but so far without a solution.You can probably play some stations on TuneIn (for instance SomaFM Secret Agent works fine for me), while others do not work at all
I have contacted TuneIn support as well, but so far with no results (they say that there have been no changes to the streams i normally use since 2017)
All in all the underlying technical problem is - to my knowledge - not yet known.Best,Ben
