Help with Beolab 7.2 soundbar
tantricman
Posts 9
tantricman Posted: Thu, Oct 28 2021 5:06 PM
The silver cover has come off my 7.2 Beolab Soundbar which is attached to my 7-40 tv and I cannot get it back on.
As i understand the covers slide on and off from the side, but as it was knocked off by mistake by a decorator it seems some of the lugs may have broken and when I tried to slide it back it just fell off.
Also a couple of pieces in the middle of the speaker and underneath the grey cloth were loose.
I am reluctant to glue(super glue if possible) but if anyone has a better idea or solution I would appreciate a reply. If no ideas what would be the best way to glue it?
T
Brian
London/Aarhus
Posts 219
Brian replied on Thu, Oct 28 2021 5:18 PM
You can get new lugs on ebay..
tantricman
Posts 9
Thanks for your reply but I could not find anything on ebay. There are plenty of speaker lugs of different types but the problem is not related to speakers but attaching the grille and there  are no lugs that I could see that would do the job.
Brian
London/Aarhus
Posts 219
Brian replied on Fri, Oct 29 2021 6:55 PM
Try with some ‘Black Tack’ (search Amazon or eBay)
That way you can remove it again rather than glue it..
tantricman
Posts 9
tantricman replied on Sat, Oct 30 2021 12:23 PM
Many thanks Brian. I will give it a go
Cheers
Adrian
tantricman
Posts 9
tantricman replied on Sat, Oct 30 2021 12:24 PM
Cheers
Adrian
tantricman
Posts 9
Cheers
Adrian
tantricman
Posts 9
oops blasted network!
Page 1 of 1 (8 items) | RSS
