Test Flight App --- TUNEIN
This post has 40 Replies | 2 Followers
Gary
Dublin, Ohio
Posts 108
Gary Posted: Fri, Nov 19 2021 11:04 PM
Am I missing something or is it no longer possible to save favorite stations in the TUNEIN section of the latest Test Flight for B&O?
ngnear
Posts 245
ngnear replied on Sat, Nov 20 2021 7:51 AM
Same here. Very annoying!
In the configuration Favourites is activated but doesn’t show.
I now have a B&O Radio tab as well as TuneIn, but it’s useless without a Mozart product.
Playing around with the “Personalize” menu causes the app to crash. So I assume still work in progress.
Tim
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Nov 20 2021 9:16 AM
I have reported it via the TestFlight feedback.
I encourage you to do the same if not done yet.
MrAndersen
Posts 226
MrAndersen replied on Sat, Nov 20 2021 10:41 AM
Thanks for the report guys. We will look at it first thing Monday.
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Nov 20 2021 10:59 AM
Same problem when I select Emerge.
No stations available.
When I press “show all” under popular stations the app crashes.
Millemissen
Flensborg, Denmark
Posts 14,680
Exactly the same here - on both my Essences.
Dyssegaard
Copenhagen, Denmark
Posts 263
Dyssegaard replied on Sat, Nov 20 2021 12:32 PM
I find it strange, that B&O-RADIO can be selected, when it is not supported by the product (Beoplay M5).
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Nidi
Posts 46
Nidi replied on Sat, Nov 20 2021 3:28 PM
Helo MrAnderson, my wish to christmastime…..
Please integrate a Sleep-Timer (30, 60, 90min) button in the menu……It would be easier than always adapting the alarm time to the bedtime…
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Nov 20 2021 9:06 PM
Nidi:
As well as a way to deactivate/activate an alarm directly from the app UI instead of having to go to the device numerous configuration screens for that simple action.
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Nov 21 2021 2:13 PM
Must say I like the new look of the multiroom page in the app.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Nov 25 2021 9:40 AM
Still no update to fix the Radio mess up…. Sad
Frederik
Belgium
Posts 94
Frederik replied on Thu, Nov 25 2021 2:25 PM
Hiort:
This issue is as far as I know limited to the beta app. It is really expected that there are issues with the beta app, that's exactly why there is a beta version.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Nov 25 2021 6:17 PM
Frederik:
Absolutely,
It’s just that MrAndersson said that they would look into this the first thing this Monday. It’s quite a big error even in a beta release.
MrAndersen
Posts 226
MrAndersen replied on Fri, Nov 26 2021 12:27 PM
Hi guys
Sorry for the delay, it turned out to be bigger than expected. We're on it and I expect a fix today or start next week.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 4:51 PM
While under construction,
It would be nice to display the radio page according to what is supported by the product itself instead of defaulting to B&O radio, should be as easy to code than selecting the appropriate product image.
liviu_o
Posts 157
liviu_o replied on Fri, Nov 26 2021 6:34 PM
@ Mr Andersen- also I cannot start tunein stations from BO app on Essence MK1….only way to listen is to start tunein on iphone and stream to Essence 😔
Any way to fix this?
Frederik
Belgium
Posts 94
Frederik replied on Fri, Nov 26 2021 7:15 PM
I do not heave a Mozart product yet to test B&O Radio but from the interface I see in the app it seems that a few additional functionalities would be required to get on par with TuneIn:
  • It seems you can only have 4 favourites mapped to the MyButtons. It would be nice to be able to manage favourites like in TuneIn where you can edit the order and map them to the number keys on the BeoRemote One.
  • In TuneIn you can manually add custom URLs for streaming of stations that are not directly available on TuneIn. I don't think B&O Radio provides this function?
  • In TuneIn you can check the bitrate of the stream, which can be useful from time to time.
If these functionalities can be supported the only remaining plus of TuneIn would be integration with other products. In general, I think it would be nice to have TuneIn on Mozart and B&O Radio on the other products. Not sure how feasible that is however.
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Nov 26 2021 8:00 PM
New release tonight.
Same problems for me unfortunately…
ngnear
Posts 245
ngnear replied on Fri, Nov 26 2021 8:35 PM
Didn’t work for me either until I “personalised” the Radio menu. Then the favourites reappeared.
Tim
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Nov 26 2021 8:54 PM
ngnear:
Tim
Not sure where you do that…
There is a setting where you can toggle eg favourites on / off but It did not help.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 9:12 PM
Same here, I don’t see TuneIn favorite fixed
ngnear
Posts 245
ngnear replied on Fri, Nov 26 2021 9:17 PM
Hiort:
Yes, this where I toggled one of the fields off and then back on. The favourites then appeared.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 9:18 PM
ngnear:
Yep, to see the favorite you must turn all the other options ON …. Another issue to be fixed by B&O
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Nov 26 2021 9:42 PM
mbolo01:
Yep, to see the favorite you must turn all the other options ON …. Another issue to be fixed by B&O BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
No luck…
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 9:44 PM
Hiort:
No luck
You must close the app (swipe up in IOS) for the change to be effective (another bug)
Millemissen
Flensborg, Denmark
Posts 14,680
The only thing that helped me, was to toggle on ALL 4 categories.
Usually I only have the first = Favourites set to on (that is what I need).
Afterwards you can toggle off those that you don’t need….and the Favourites appear Lets have a Party !!!
Not very intuitive, but it worked.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 10:26 PM
Millemissen:
Up to the point you close/start the app. The choice is not persistent unfortunately
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 10:29 PM
Also, when all radio options are turned on, despite you are only a TuneIn user, B&O radio page is showing « my radios » which are not my radios
Millemissen
Flensborg, Denmark
Posts 14,680
mbolo01:
What do you mean by ‘close/start the app’?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 10:32 PM
Navigating in B&O radio localisation pages crashes the app
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 10:33 PM
Millemissen:
Close = swipe up the app in IOS
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 10:37 PM
Millemissen:
Hopefully this answer will not go to moderator:
https://support.apple.com/en-us/HT201330
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Nov 26 2021 10:40 PM
Millemissen:
3rd attempt to answer.
Below is a link to how to really close an app on IOS:
Millemissen
Flensborg, Denmark
Posts 14,680
mbolo01:
I have a few stations there, which I don’t know about and why they are there.
They can not be started. Funnily I can search for stations there.
I wonder what that might be - probably still something unfinished.
N.B. I have no Mozart products (yet).
Millemissen
Flensborg, Denmark
Posts 14,680
mbolo01:
Millemissen:
I sure know how to do that….but why should I?
I only close an app, if it is misbehaving.
https://discussions.apple.com/docs/DOC-13491
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Nov 27 2021 8:03 AM
TuneIn favorites should be exposed like other groups, I.e. a sliding bar that you can turn into a list to see more.
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Nov 27 2021 2:23 PM
Strange,
I can’t get it working.. killing the app completely, toggling settings.
No joy. Unsure
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sun, Nov 28 2021 3:39 PM
Hiort:
Despite the fact that selecting all radio options makes TuneIn favorite visible, tapping on radio tiles does not start anything. I wonder if the dev team have a decent testing environment or maybe we are alpha testers ?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Nov 28 2021 4:10 PM
Balance: select a tile on B&o radio starts the station. Select TuneIn, response source not available for product.
M3: select a tile no radio, not B&o radio not Tunein. Select a station on TuneIn, and selecting Play now afterwards does start the station..
so beta.
edit
removing favorite in TuneIn works on the M3, add TuneIn favorite on M3 works.
Searching station works. Then selecting the tile does start the station.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Dec 1 2021 6:41 PM
Well done Mr Andersen, Radio are properly working now.
Page 1 of 2 (41 items) 1 2 Next > | RSS
