Beolab 5 mic calibration not working
This post has 4 Replies | 0 Followers
Rtyu7
Posts 20
Rtyu7 Posted: Tue, Dec 7 2021 10:50 AM
I brought used Beolab 5's i press the mic calibration button on one for over 3 seconds then let go nothing happens.
Green light flashes the whole time Beolab 5 is switched on and when music is playing.
What could be the fault ?
Rtyu7
Posts 20
Rtyu7 replied on Tue, Dec 7 2021 10:55 AM
Will i need to buy a whole new chasis? How much does a new chasis cost? Shall i change chasis myself ?
lawrencejmcook
Posts 742
Just a couple of reminders in case:
- The speaker must be in STANDBY mode in order to calibrate it.
- The amount of pressure on the top “button” can vary. One of mine needs just a touch, the other more of a press.
- I think it takes longer than three seconds. Keep pressing until the light goes red. Try waiting up to 10 seconds.
If the speaker will no longer calibrate itself you should get it checked out by an experienced BL5 repairer.
Rtyu7
Posts 20
Rtyu7 replied on Wed, Dec 8 2021 12:09 AM
In standy the light is red so what do you mean by keep pressing until light goes red ?
lawrencejmcook
Posts 742
Sorry - I should have said “starts flashing red”.
Page 1 of 1 (5 items) | RSS
