Standby battery use BeoSound Level
This post has 8 Replies | 0 Followers
marcengels
Posts 44
marcengels Posted: Wed, Feb 24 2021 5:06 AM
Hi guys, is it normal for the Level to use almost 10% battery while in standby? I mean turning the Level off using on/off button for 2 seconds till you hear the beep. In the app I can see it uses almost 10%!
So in 9 or 10 days it will be dead without using it.
Thanks for any reply.
BeoHocke
Posts 3
BeoHocke replied on Wed, Feb 24 2021 6:29 AM
I observed the same with my Beosound Level...
leosgonewild
Helsinki, Finland
Posts 2,373
Standby on battery is standby on battery.
They are not magicians down there in Struer.
Pretty close tho Big Smile
kuyttendaele
Posts 707
Standby is not "off"... It means that it is still using power!
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Feb 24 2021 8:28 AM
kuyttendaele:
One could argue, that 10% usage in standby, is still rather high though? I mean, shouldn't it just keep a low power access to the WiFi, so it can be woken by the app ? It is spec'd as 4.5W standby power usage.
But, I guess this is why they designed the charger to be nice looking, and easy to use ;)
/Weebyx
marcengels
Posts 44
How is it standby? I can't wake it up by saying heey Google nor can I turn it on using my phone or Beoremote one! It should be using no power at all!!
trackbeo
Posts 644
trackbeo replied on Wed, Feb 24 2021 9:20 AM
By contrast, a BeoSound 1 (non-GVA version, if it matters?) uses only 1% to 2% of its battery per day, when left off its mains power, and turned off.
An off-brand comparison: The Sonos Move uses 4% to 5% of its battery per day, when in "full" power-down mode (long button press-and-hold until beep).  In only standby mode (short button-press), the Sonos Move chews through its battery very quickly, maintaining its Wi-Fi connection and fully powering up at random times to do who-knows-what for up to a half-hour each time!  It has been released for 5 months with no change in its battery usage by way of any software update, so I think we must expect that it won't be improved unless the hardware is changed.
Such power consumption makes one wonder what on earth these devices are busy doing, when supposedly powered down?  Monitoring a single soft-power button should be all they need, but maybe that hasn't been separated from the full display/multi-button driver chip(s)?
10% / day makes the "occasional bathroom / shower playing with a weekly recharge" use case impossible.
ohforf
Posts 1
ohforf replied on Tue, Dec 7 2021 10:27 AM
Hi everyone.
Sorry for a slight off-topic, but I've just read here that after turning the Level off completely, you have to connect it to power supply in order to turn it on again.
To me this looks like a quite strange and annoying feature, especially due to the fact that the stand-by mode eats the battery up so quickly.
Can anybody confirm this? Or have I misunderstood something?
Curly
FL, USA
Posts 366
Curly replied on Tue, Dec 7 2021 11:44 AM
I keep my Level off when not using it. Yes, the battery drains quickly even when totally off. And no, I don’t need to connect it to mains power to turn it back on. (I have non-GVA.)
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Page 1 of 1 (9 items) | RSS
