Hi there,
I'm restoring an old Beocenter 3300 for a friend. The balance pot was broken, so as the tuner string. Thank you everyone in this forum for the infomrations about how to dissasemble the beast...
I've changed all the old electrolytic capacitors, set up the no signal current. It works fine, the sound is great.
But, the volume is very high when playing the tuner, compare to the tape input. I've found a thread about a similar issue on a Beomaster 2200, that seems to be the same machine, without any conclusion.
What do you think about this?
All the output currents from the power supply board are OK.
Thanks,
Axel
