Hi, my first time post. I have a Beolab 3500 set up professionally as part of a larger system. It has now stopped communicating with my remote. The remote is fine and the speaker is fine. I have switched the speaker with another and it does not communicate either. Any suggestions?
I have one that does the same. Probably the IR module needs replacing. Check the option settings fist though.
