Beolink 1000 not all Buttons are working
This post has 2 Replies | 2 Followers
Oxotron
Posts 5
Oxotron Posted: Fri, Dec 10 2021 5:32 PM
Hi there,
I own a Beosystem 2500 with a Beolink 1000. First of all, I cleaned the remote including the battery contacts and gave her fresh batteries. It works so far.
But only the following functions:
Radio on
Volume +/-
Station memory only up
Tape recording
Standby
All other buttons / functions do not work.
Is that a defect or a feature? I can't find anything about it.
Hallo,
in habe eine Beosystem 2500 mit einer Beolink 1000 ergattert. Erstmal habe ich die FB inkl. Batteriekontakte gereinigt und mit neuen Batterien versehen. Sie funktioniert auch.
Allerdings nur folgenden Funktionen:
Radio an
Lautstärke +/-
Senderspeicher nur hoch
Tape Aufnahme
Standby
Alle anderen Tasten / Funktionen gehen nicht.
Ist das ein Defekt oder ein Feature? Ich kann dazu nichts finden.
Ravsted
Denmark
Posts 345
Ravsted replied on Fri, Dec 10 2021 7:19 PM
Take it apart. You find the screws on the backside and maybe some in the battery compartment. I do not remember anymore. It's been a while since I had one myself.
Clean the inside ... See if it helps.
Regards
Ravsted
Oxotron
Posts 5
Oxotron replied on Fri, Dec 10 2021 7:36 PM
Hi and thanks.
I already did this before. Without any change. :(
Page 1 of 1 (3 items) | RSS
