Where was the CD mechanism located when you took the photo? The CD mechanism (sledge) needs to be at CD position #1 for the adjustment screws to become visible. Position #1 is closest to the button used to raise/lower the glass door that's found along the lower front edge.
Bill
Bill Briscoe:Hi, Where was the CD mechanism located when you took the photo? The CD mechanism (sledge) needs to be at CD position #1 for the adjustment screws to become visible. Position #1 is closest to the button used to raise/lower the glass door that's found along the lower front edge. Bill
