The slick Beo1 remote - compatiblity and modification
This post has 1 Reply | 0 Followers
alebouthillier
Posts 11
alebouthillier Posted: Tue, Jan 4 2022 3:30 PM
Hi beovirus community,
I am referring to the original Beo1 https://beocentral.com/beo1 not the new Beo one remote.
This original remote used the same frequency as beo 4 but seems compatible only with the Beovision 1 and Beocenter 1.  Anyone succeeded in modifying its electronics or hex code programming so it could work with Beosound 9000, moment or other less vintage B&O products?
Best,
Alex
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Jan 4 2022 4:14 PM
Beo1 remote was built for BV1 and BC1, but it can control all Beovisions, that are controled by B&O IR (455 kHz) code.
Beo1 can even control audio products like BS 9000, BS 7000.... but only via videomaster (Beovision) - it has no source buttons, so you need to select sourec by Beo4, Beolink 1000..
https://archivedarchivedforum2.beoworld.org/forums/t/29071.aspx?PageIndex=1
Hope this helps
Stefan
Page 1 of 1 (2 items) | RSS
