beogram 3500 cd 4500 cd
This post has 10 Replies | 1 Follower
mpdawes
Posts 15
mpdawes Posted: Fri, Nov 9 2012 10:09 AM
hi there all does enyone no if there is eny differance between the models exept the front covers one being a dull and the other being a mirror affect top ??? are the working the same   could the laser be taken out of the 3500 cd player and put into a 4500 cdplayer
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Nov 9 2012 10:56 AM
The laser module can be one of several different types in both players and they are basically all interchangeable as long as you keep the
servo boards together with their respective laser blocks but why swap modules if you can just repair it and have both working,
what are the symptoms ?
mpdawes
Posts 15
mpdawes replied on Fri, Nov 9 2012 12:40 PM
hi there martin thanks for the relpy  the cd does spin but does not play after a second or so it sounds like the cd laser or arm fricks from one side then back as you can hear it hit one side then hit the other .
regards.
mick.
Dillen
Posts 13,191
Dillen replied on Fri, Nov 9 2012 4:08 PM
Clean the laser lens with a little tapehead cleaner (IPA) and a cotton bud.
Still no luck, replace capacitors on the servo board (a kit exists, electronic knowledge and tools required).
This normally cures the majority of faults looking like a dead laser.
mpdawes
Posts 15
mpdawes replied on Fri, Nov 9 2012 4:43 PM
martin thanks very much for your advice i will try the things you have said and let you now the out come i have also bought a 3500 as a back up for part or just swop the covers as the 3500 is in full working order .thanks again
regards.
mick#
mpdawes
Posts 15
mpdawes replied on Fri, Nov 9 2012 9:40 PM
hi there martin check this one out if i stand the unit in its edge ie stood up on its end the cd will play after afew attempts at starting it .???????strange eny ideas ?????
regards.
mick
Dillen
Posts 13,191
Dillen replied on Sat, Nov 10 2012 8:06 AM
Jitter in the supply to the radial circuit.
Replace capacitors.
twonca
Posts 5
twonca replied on Mon, Jan 3 2022 1:59 PM
Hi Martin I know this is old thread,but do you still do the capacitor kits for the 4500 cd?cheers
Dillen
Posts 13,191
Dillen replied on Tue, Jan 4 2022 3:51 PM
The CD servo kits are in the webshop at Beoparts-shop
twonca
Posts 5
twonca replied on Tue, Jan 4 2022 5:00 PM
ok cheers Martin.
twonca
Posts 5
ok cheers Martin.
Page 1 of 1 (11 items) | RSS
