Hi there,
I have a pair of black Beoplay S3 speakers that have always worked perfectly - feel lucky based on some of the connection issues I read on here...
Anyway - wanted to put them onto floor standing brackets, but can't work out what I need on the stand to fix properly to the speaker?
Can anyone recommend a floor stand or is there a name for the type of fixing required?
Thank you!
I know of none but these:
https://www.vebos.co.uk/vebos-floor-stand-b-o-beoplay-s3-black-set.html
Thank you Lawrence,
Great info.
The Vebos looks like a quality stand, but a bit bulky for me. If I find a work around - like the camera tripod - I’ll let you know.
Kind regards
I think a white or silver color Vebos is not to bulky but I would take a second hand floorstand from Beolab 3 or 4.
Create your own metalplate with 3 holes and srews and you have a nice DIY Floorstand for your S3
I create my own tablestand for my BeoRemote Essence .... there is only one in this World ....
