I've bought a nice Beogram 2200. At first sight everything is working correctly but there is one silly problem I'm not able to solve. When I press start the arm swings to the beginning of the record and starts playing. At 80% of the record (10 a 20% from the middle) the arm stops moving inwards. As a result the music skips over and over at the same position. Changing cartridge, needle pressure and antiskating does not solve the problem. Pressing stop works also without any problem: arm moves up and returns to begin position.
Hope someone can give me a hint for solving this problem.
Regards,
René
