TrueImage VS Dolby Atmos
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Sat, Aug 8 2020 11:05 PM
Ok, so I just built a 7.2.4 system with a Denon x4500.
But I suddenly bought a Beosystem 4 second hand.
If we don’t consider the 4K issue, what will give me the best sound?
I have an extra BL 14, so I can add some speakers.
My current speaker stock is:
3 x BL14 (2 x S8 mk1 and 1 x BL14 to be precise, but to make the discussion easier we call them all BL14)
13 x satelittes
4 x Beolab 4000
1 x Beolab 7.1
I also have a BS9000 I would like to use, and a ProJect record player.
My display is a LG Oled c9 65”
Looking forward for your input 😀
Mikipidia
Posts 2,169
Are we talking moviies only or film and music?
Also easy of use, or pure sound?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
leosgonewild
Helsinki, Finland
Posts 2,373
It will be used for both movies and music.
Not sure what you mean by ease of use? Smile
Mikipidia
Posts 2,169
Well i suspect that with a regular avr you have to change modes to listen to music as the movie tuning is way off.
I actually suspect the bs4 is the overall winner as it had the advantage of exactly know how the beolabs react to input and how it sounds with music. The regualar avr will probably slightly beat it on atmos movies as it knows what to do with the distance metadata and a bit better what to do with height channels for an atmos track. Proof is in the pudding i guess so test itBig Smile
I have a feeling it’ll be close as the trueimage is actually really good for effects and height experience.
swestland
Netherlands
Posts 73
swestland replied on Fri, Feb 4 2022 11:25 AM
When I'm playing a 5.1 LPCM source, my speaker group is 5.1 also. It still shows as 'downmix', right?
- Beovision Eclipse 55 Mk2 - Beolab 19 - Beosound Shape - Oppo UDP-203
Page 1 of 1 (5 items) | RSS
