Hi everyone,
I'm looking for a subwoofer that suits my Beolab 18 speakers.
Now I have heard that a Belab 11 would not be a good combination because the bass in the Beolab 18 would be sufficient.
What is your experience, is a Beolab 11 an addition or should I look for a Beolab 19?
Kind regards,
Ramon
Hi!
I have tried BL11 together with my BL18, and I felt it was underpowered. Maybe the BL11 will kick in on higher volumes..
Two weeks ago - I added a BL19, and wow! A very different animal than the BL11.
Deep nice bass, also at lower listening levels.
/robert
Well, Haven't tried it, but the specs of Beolab 18 states frequency 27-23000 and the Specs for Beolab 11 states as of 33, means it cannot go as low as the Beolab 18---I would think if you need more Bass, a Beolab 2/Beolab 19 is your options--
Regards
OL
The 18’s goes down to around 40hz..not 27hz..
yeaah, you're of course right, I had the specs from Beolab 28, all good
